PHOTOS Added at bottom click to enlarge. & help
kodibass
I can find no plate with the sn/mod# for this 19?? 30 hp jonny I looked in around the transom bracket, sides of clamp housing etc. I did find numbers on the silver plug on the block the are as best I could tell 3169219 I am trying to get the year so as to order parts, any help/ suggestions/ are very much appreciated .
kb
Lostfisher
Re: model & sn #plate missing. other #'s
r u able to post a pic of the motor. give us a better description of the motor
1fishbone
I remember reading a post about this a couple of days ago.
Try "new posts" and go back a few days.
F_R
Honorary Supreme Mariner
That serial number puts it in the 1969-1972 range. But they didn't make a 30hp during those years. Sounds like it may be a chop shop motor.
kodibass
I'll post some photos tomorrow, I think all is original but the bonnet may be off a 25, I sometime get them mixed up.. thanks KB.
kodibass
Re: model & sn #plate missing. other #'s JPEGS ADDED
Here is the motor in question, I need the year to order a recoil starter spring, iboats part# ? all help appreciated.
kb
oldcatamount
I think it's a mid/late eighties motor. Not much help I know but without the numbers I can only guess.
Lostfisher
According to the ignition coil part(582508) number in the picture the year of the motor is somewhere in the 85-91 range but that is for a 25hp the 30 takes a different part number. Also i see ur fuel pump is missing in the pic #3.
I believe this is the recoil spring you need it covers all motors from 85-01 in the 25-30hp range. just double check it first before you order.http://www.boats.net/parts/detail/brp/B-0395460.html
F_R
Double check the first number in that serial number. Maybe it isn't a "3"??
blimp
Re: PHOTOS Added at bottom click to enlarge. & help
i would guess 88 or 89
kodibass
Thanks all. iboats ROCKS!!!
G DANE
It also looks like the rear mount for the recoil start is missing. Is the motor rotating and has fair compression ? It looks like it was very wet with salt water once, but it doesnt have to mean anything.
