Picked up a 86 Sting ray with a 120 HP/alpha 1 gen 1...was winterized. Noob questions
Im guessing a 3.0 wouldn't exactly bolt in now would it?
Ayuh,..... It should bolt right up, 'n the 3.0l is much more common,......
Btw,.... a GM 2.5l outa a car is a completely different motor,.....
ianbword
Thanks yeah if I happen to find a marine 3.0 in my area maybe ill go that route since its coming out anyways. Def a marine motor regardless of what goes in.
thumpar
You would have a hard time finding a 3.0 that is not a marine. I believe they may have been used in industrial equipment but I have never seen one other than marine. You should be able to find them all over the place in rotten bayliners.
3.0's are a dime a dozen... they come in rotten boats that people want to give away for free
ianbword
So will a 2.5 starter, fuel pump, and carb work on the 3.0? I assume the carb would need to be re adjusted.
And as far as my outdrive goes...do I need to find a 3.0 out of the same exact year as my boat to match up with my Alpha 1 Gen 1?
achris
More fish than mountain goat
Starter, fuel pump, alternator and the like are all exactly the same. Distributor and carb will be slightly different. Drive ratio is exactly the same, 1.98:1... No change required there, but you may need to go to a bigger propeller (almost certainly! :D).
Any year 1982 to 1991 should fit. Bondo Rear seal?
Chris...........
