TruckDrivingFool
- Joined
- Jul 30, 2007
- 1,818
I'm trying to pick a prop for my 15' Starcraft Jetstar w/ a 50hp Johnson. (sig link below) Until I started reading here I just thought a prop was a prop but now see the need for fine tuning. I now understand the effect of pitch on RPM's but not the effect of diameter.
Right now it has the factory 13 1/4 X 17 prop and @WOT I get 29mph (phone GPS) @ 4800 RPM with my standard load. The motor has manual T&T and have that set as best as possible. I had figured I would go to a 13P and be about the sweet spot. Then I started looking for one and discovered that to get the pitch I would have to go bigger by 1/2" to 3/4".
My service manual lists 5-6000 for WOT throttle w/ peak power @ 5500. It also lists alt. props up to 14" So I've eliminated my fear that my choices wouldn't fit but now I wonder if I need to figure that little bit extra diameter into my choice.
