pickup point timing & throttle cable adjustment
WestPoint
I have a couple of questions regarding pickup point timing and adjusting a new throttle control cable on crossflows. I have a 1986 Evinrude 90hp.
After setting the cam follower pickup adjustment (using a shaft amplifier) to the pickup point (follower aligned with cam mark just as the carbs start to open), I had to adjust the idle screw temporarily so as to hold it at this position while I checked the pickup point timing. Otherwise engine vibration kept moving it while I adjusted the timing to 4 degrees BTDC per manual using the thumb wheel.
Now here is my question- before reattaching the throttle cable (a new one so I can't just go by how it was), should I match the cable to where the cam is at this pickup point (4 degrees BTDC and cam follower aligned with cam mark), or should I set the idle screw to some other initial setting first- perhaps something less than the pickup point?
In other words, after warm up and in neutral, when throttle control lever at control box is latched - should the cam be somewhere before the pickup point (where carb shafts are still closed) and there is still room to advance spark before they start opening, or at the pickup point ( where carb shafts have will just begin to open, timing is at 4 degrees BTDC and cam follower is aligned with cam mark), or after the pickup point, where carbs have already opened?
tashasdaddy
Re: pickup point timing & throttle cable adjustment
Installing control cables.
1. set controls in neutral and at idle.
2. manually make sure motor is in neutral and at idle.
3. on the motor end of the cable, is a trunion nut (adjustment nut) there is a retainer, on
the motor for the trunion nut remove the clip.
4. without moving anything on the motor, adjust the trunion nut (turning nut) so that
The nut sits in the retainer, and will connect to the motor.
5. connect the cable to the motor, reinstall the retainer clip.
Note: you adjust the cable to the motor, not the motor to the cable.
WestPoint
Yes, but when you adjust the cable to the motor, is the motor supposed to be at the pickup point (carbs closed, follower aligned with mark and timing at 4 degress BTDC), before it, or after it?
Later, on water, boat unrestrained we set using idle screw to 650 rpms. Just want to know if the pickup point is where to initially adjust cable at.
