Re:stringers, Need advice!!
G'day Drew,
Its a bit hard to see but it looks like standard resins were used over the timber, this will not stick long term and will part under stress.
Standard poly resins over stringers is fine provided the stringer is not made of timber. Early boat builders used timber because it was cheap and available, however they now know it will not stick long term because of the natural oil in the timber and the fact that water will eventually penetrate standard resins and the timber will rot.
Most small stringers now contain foam that is used to used to form the required shape of the stringer and extra glass is applied to replace the missing timber, resulting in a much lighter and stronger stringer that will last.
Timber can be used provided its treated first; this means it MUST be very dry and epoxy resin applied to seal it against moisture ingress.
Thinning the epoxy resin helps penetration, this can be done by adding Methylated spirits to the resin after the resin and hardener has been mixed, you can add up to 40% by volume or weight as the variation between both is very small.
End grain will require a lot more coats as the resin is drawn into the timber, this is very noticeable if ply is used. A mixture or epoxy resin and Micro-Fibres makes a very strong and water resistant glue when you join two sheets of ply to get extra thickness.
You can avoid a lot of washing and sanding between coats of epoxy by applying wet on tacky.
Also note:
Epoxy resin will produce a stronger bond to standard poly resins than Standard poly over poly will. However, poly resins should not be applied over epoxy resin as the bonding will be poor, always use epoxy over epoxy; and remember that most epoxy resins need a coat of paint to protect them from UV light.
I hope this helps.
Andavagoodnewyear......
