Picture of someone's motor and where the wires all go
michaelkeb
I have reinstalled my aq225d back in my 1985 bay liner cierra. The wiring I'm still having trouble with. Does anybody out here have a picture of their motor and where all the wires are hooked up? I've been looking but am having trouble finding anything. I can't get power to anything and that's all I need to be able to get my boat back in the water. Please somebody help me out with a picture of your motor and where all the wires go! PLEASE!!
Lawnpro979
Be sure to Check your Fuses, I have been is a sit, Like this b4. and come to find out I blew a couple of Fuses, after chaseing down wires for 2 hours
UncleWillie
After 30 years, a picture of what color wire, is attached to what terminal, in another boat would be folly.
The power from the Ignition switch goes to the Ignition.
The starter wire from the Key Switch goes to the Starter. ... And so on ...
Get those two proper an you can start the boat.
Trace the wires, and use a meter to confirm that you have power where it is supposed to be.
If you have specific question about a specific component, Ask! We can help figure it out.
It would be unreasonable for someone 700 miles away on the internet,
To be able to tell you with any confidence, where you should attach your Blue wire with the Red Stripe.
I can't get Power to Anything!
What is the battery voltage?
Same After the Battery fuse?
Same at the POS bus?
Same on the B Terminal of the Key Switch?
It's a Beginning!
