weezzell_5400
Thread starter- Joined
- Jul 25, 2012
- 51
Ok so the motor is a 1987 120hp evinrude ....small bore ....here is my spill....the motor had low compression when I got it a few days ago...all cylinders around 58 to 60 psi....checked with 2 separate gauges....its been sitting up for about 7 or so years ...but has great potential...has an awesome spark ...and overall everything looks great ....so I pulled out the telescoping gauges and the micrometer ....and the cylinder walls are reading right around 3.4975 ...and one right on the dot of 3.5000.....so the bore of this motor is supposed to be 3.5 stock....so my question is ...can I replace just the rings ...or are the rings specific to each piston and have to do full piston and rings ....the walls of the cylinders look great ...but one has a little rust or something at the very edge that can be cleaned up with a light honeing ....
