fishfeatures
Thread starter- Joined
- Mar 29, 2011
- 743
I am rebuilding a 1990 60hp Johnson, alarm went off and upon inspection it needed honing.
Anyway, I have all pieces ready to put this motor back together, but yesterday as i was replacing the rings (re-ringing only not new pistons) I found that the bottom one wouldn't compress too well in the groove.
they are OEM .0030 rings and the ring gap was measured and is within spec. The issue seems to be the the ring doesn't slide/ move freely when in the groove. No issue with the old one and i am putting the rings on with the pin in the gap.
I thought that maybe a build up of carbon was the issue so, I broke an old ring and used that to clean the gap (found this tip on an old post), got a bit of carbon but not alot out adn the ring still seems to be sticking at the LHS of the gap.
Top ones no issues it's only the bottom ones.. is it a case that the piston is not OEM and so the groove and ring won't fit ? Is it uncommon for rings not to be an exact fit?
the old rings look shinier than the new ones so maybe they are different .
