driver_dav
- Joined
- May 1, 2013
- 96
Background on this project:
I have a Maxum 2100sr with a 350 engine in it, it sat for 10+ years and was rough turning by hand after having some fogging oil sitting in the cylinders so I have decided to rebuild the engine, upon teardown I have found water had sat and rusted in the Intake, Heads, and cylinders 7 and 8 had some rust. Everything has cleaned up very well rust wise, and I have regrinded the valve seats down and got them all cleaned up now my next part is the block, Most all the rust came off with oil and scotch pad there is a very minimal layer that I think will come out when I hone the cylinders because the rings need replacing. I have found a tag on the front of the block that says reman # also the top of the piston says .040 does the mean it has been bored over?
So my main questions is if they are bored over what size rings will I need?
Do I have to have Marine rings?
