udoittwo
Thread starter- Joined
- Jan 23, 2014
- 73
I can't figure this out. I know I make mistakes and that I can deal that and I'm hoping I've done something wrong that is fixable.
I'm assembling the rods to the crank and they won't clear the crank. If I spin the crank, the skirt of the piston hits on the counter weights of the crank. I'm using the original crank and rods, I measured the length of the skirt from the wrist pin to the bottom of the skirt and they are the same as the factory originals. Neither rods nor crank were cut, only polished. The roller bearings are smae diameter as originals.
I know I was in a real hurry to dissasemble it all to get it to the machine shop before they closed but I am fairly comfortable with keeping everything in it's correct place and order. Even IF the rods were on wrong could it make a difference of that much. I could see side to side differences but not length. It looks like I need nearly a 1/8" give or take, more clearence. The overall height of the piston is a little shorter on the new ones but again, the wrist pin to the base of the skirt height is the same.
This is a 1986 75 Mariner 4 cyl. #A199493. If anyone knows Mercury parts, are these the correct pistons "MERCURY 2.875 BORE .5MM PISTON WSM PART No. 100-15-05K"?
It has to be something I missed.
Thanks for any suggestions,
Karl.
Karl.
