I have a question to pose about piston weights on partial overhauls.This subject has been debated several times from differing view points as to whether it is feasible to change one piston as opposed to changing all as a balanced set.I have done some thinking on this and have come up with this figure that I hope will be easy to interpret.<br /><br />Say as a hypothetical,a compression test revealed two cylinders that varied 10 psi.One was 100 and the other was 110.The bore was 3" .Assuming it is safe to say that the exertion of the differing pressures could be looked at as weight exertion or imbalance.<br /><br />So if the square inch of the bore was pi x (radius x radius) then the area is 7.065 or say 7.<br /><br />Is it feasible to figure that 1 psi or 16 oz.per square inch divided by 7 square inches = 2.28 oz.of differing weight exertion to crank?If the pressures differed 10 psi then 2.28 oz. x 10 =22.8 oz.<br /><br />Would it be logical to summize that these particular bore cylinders would have an acting weight imbalance of 22.8 oz.?<br /><br />If so,would two pistons that varied in weight of say 3-4 oz.on equal compression cylinders pose less balance problems than cylinders whose pressures varied 10 psi?<br /><br />Or am I looking at this all wrong?Hope this question is understandable to some of the physics gurus.Thanks for any replies.
