Re: pistons of varying weight
Well, I'm a retired engineer...but I've been wrong before
.<br /><br />My guess is that the three standard pistons were installed as a matched set all weighing the same. They probably weighed the same as the other three that were replaced too. And when the three .030 oversized pistons were purchased, they too came as a matched set. They just didn't match the others since there was only three. Usually a matched set would've included a total of 6 pistons.<br /><br />Is the weight change because of the displacement change? Tough one. I suppose it is possible since balance is affected by F=MRw^2. Here a reduction in mass would reduce the force. And an increase in angular accelleration would increase the force. More displacement usually increases compression. More compression usually raises the angular accelleration of the piston/con rod with regard to the crank (more power). So I suppose in an attempt to keep the force equal, reducing the piston weight might compensate for any added angular accelleration.
