Hey guys I've got a problem. I cut out my plywood { two 3\4 pieces and one 3\8} And was going to glue them together with PL and stainless scews outside the boat then glue that piece into the transom. I coated all three parts with epoxy and let them dry. Then I scuffed them with 60 grit and applied PL with a notch trowel and screwed them together and let them dry for 24 hours. Problem is I just drilled a hole saw through it because I was going to do a rough cut for the outdrive and the glue is still tacky. Will this harden or should I not have coated the wood with epoxy. And should I use PL to glue this piece to the transom. Thanks for any reply.
