Re: Planer boards
I thank you Digbat, I will be makeing myself a set.
You use a old rod to reel it out but I was wondering if you could use an old downrigger and it's cable or would the steel cable would be to heavy.
1x6 pine boards are ok on smaller waters. I made my own in the 1x6 plan, and spar varnished them of course. Used ice-fishing tip-up flags for safety markers, but you can't miss that shiny pine board anyway
I think the beveling of the angled edge is critical to them running well. 80# fluorescent orange monofilament pulls them just fine.
However, on seeing other boaters' home-made boards operate, I think that a strip of weight on the bottom edge as ballast on the outside board would be an improvement. I have also considered just selling the 1x6 boards and making new ones with 1x8s- I saw some taller boards with a little bottom-edge ballast and they ran almost 90-degrees from the boat. Mine do not drop back much, but they do drop back a little.
I also used maple sugaring line to cover the threads of the bolts between the boards. It just barely fit over the bolts, and I had to work hard to get it on the 5/16 rod. It seemed like a good idea at the time BUT it creates too much resistance in the water I think. Maybe I will append this post in summer after a little experimenting.
Downrigger reels would work well, but I made my own with a 4" hole saw for the cores and 8" circles cut from 1/4" baltic birch. I varnished them well (spar varnish, not urethane!) but the baltic birch doesn't have waterproof glue so I may not have them last forever, but all the material was free and leftover and making them did not take very long.
