Re: plasti wood instead of wood that rots?
ondarvr,
You made me rethink my plans. Still going the composite route, but decided to use Coosa Composites Bluewater 26. Found it local and ordered a few sheets. It's $200/sheet, but should outlive me.
Ben
I reckon that material sounds good but can be found cheaper...
Put on a high vis jacket, grab a screw driver and a battery powered drill and go for a walk down to your nearest bus stop after dark... Preferably WAY after dark.
Proceed to 'REPAIR' the thick plastic and perspex sheeted walls and remove all and anything even similar to your abode.
Hey presto.. You have just committed an offence and are now the proud owner of some.. uh, plastic stuff that may or may not be suitable for boat building.....
Just try it anyway!
****, that gives me an idea!
Refurb your under-floor stringers and whatever, clean it all up and glass it in.
Install a 12 volt insulated cable pair with a few led lights at intervals under there.
Lay down a few sheets of perspex and glass in.
Operate switch to illuminate under-floor lighting live happily ever after knowing that you can check the condition of your boat flooring at any time....
Plus, at night, whilst fishing you won't be able to see any lights or landmarks due the brightness of the floor.... It will be dangerous but you'll be the only boat out there with a disco dance floor.
Going off to do it with mine RIGHT NOW!
