Chopperbill
Thread starter- Joined
- Mar 26, 2014
- 389
Are these things durable? I'm always leery of anything that supports weight made of plastic.
question...if i wanted to permanently mount that plastic seat to my bench seat....how do i do it with a swivel and not have it stick up some ungodly amount...id like it as short as possible
Actually it's hard to find them without the cushions. Not much more money but I'm not sure if the cushions would hold up.Actually a lot of new boat seats are built on plastic frames these days. I bought two high-end bass boat type folding seats and they are built on plastic frames. So I guess they will hold the weight and work nicely. I think they even make some nice seat cushions for those seats you have to make them more comfy. And if you want to change the color, I think Krylon Fusion will take care of that as well...
I thought about getting one of those for my Achilles and mounting it to the bench seat
I used the lazy susan style swivel that RonaldJ shows above. it only adds about 2-3 inches in height and the swivel feature adds functionality on a bench mount otherwise you must ALWAYS be facing straight ahead or in the position you mounted it... very hard to do for any length of time. As for sea riders comment about support, that is ultimately why I stopped using mine. When the boat is stationary (at anchor or drifting but not underway-no motor power) the seat is fairly stable, but once moving at speed, there are a lot of rotational/ torsion forces acting on the bench and transferring to the mounting points on the boat. Since there is overhang on the seat... the lever moment forces are greater than those produced by the plain bench alone, and I was afraid to tear the patch/ mount from the hull. I am 220lbs, so my concerns may be different from yours... at say 150#, I would likely not even have thought about it.
That looks very nice but knowing my self i would trip over the frame and go flyingI was worried about the seat bench being floppy if you attached a seat to it. So, I have this mount as my next purchase.
Would preffer 2 alum bench seat and corresponding side holding patches and 2 alum squares, each bolted to both bench ends and middle bolted mount chairs for better ballance of boat, as opposed to side mount as in attached picture. You can even install same way with wooden standard benches.
Happy Boating
Emailed to see if I could use a higher pedestal on the adjustable seat frame as the shown is only 7 inches. Hip problems prevent me from sitting that low. I got an honest response so I am glad they are not out to just sell products like some dealers. Thought I would pass along that info.
"I am not sure if it would be safe to use higher pedestal. We only tested that frame with lower pedestal. Frame itself is strong, and I don’t see it break because of higher pedestal, but then if you will be riding boat sitting higher, frame can pop out from boat on a wave or at higher speed, and you can get injured. It is up to you how you going to use frame, but for legal reasons we can only advice using regular short pedestal."
