Play in Shaft in Alpha 1 Gen 2
Bt Doctur
it`s normal, when under power the gearset is driven upward to set the correct clearance
subysti
thanks, I was concerned about some noises I was hearing when running with the drive up that I thought may be the U-Joint which is an easy fix. This wouldn't be.
thumpar
Don't run with the drive up above what the trim switch will allow.
