PlayD0h
Thread starter- Joined
- Apr 23, 2009
- 331
I also spent a fortune on materials. Mainly paint and 'varnish'. I went in to the Industrial plastics and paints store just looking for self etching primer, and to ask about Spar varnish vs epoxy. He recommended a "system 3 epoxy sealer", which would have cost me $200 to do the deck, transom, and apparently I could have primed the boat if there was enough left.
I ended up getting 2 quarts of Rustoleum Marine bare metal primer, and the same Rusto Marine 'TopSide" paint. Yet after thinking about it, I'm not sure it was the best route, and I might try and return them. There for Above waterline, and the thought of doing a 2 part paint job isn't appealing.
I am wondering if it would work below the waterline, since at the very most I could see me using a marina slip for say 2-3 days, yet I could also easily not use one. Its hard to imagine a "Marine" paint that would be effected by being underwater for at most 8-10 hours at a time, say 2 dozen times a year. Thoughts?
I've found the threads asking the same, and have read that some say its ok for 2-3 days at most, some say its ok for 12 hours at most, and others who say don't do it. Going against the manufactures directions is not a chance I really want to do, without good assurance its been done before.
That, and the fact, its probably more expensive then the "tractor" rustoleum. I'm just unsure of what to do at all regarding paint, since theres a few methods recommended, and finding the suggested paint here in Canada isn't easy. They sell Rustoleum here in Canada, yet also Tremclad, which I'm sure is the same thing, as its made by the same company. Yet why the name change here, I have no idea.
Its either a $500 epoxy paint job, with or without the extra $200 for Alodine, and alumiprep. Or the sand, acetone, vinegar, etching primer, Rustoleum bare metal primer, then either another coat of regular rusto primer, or rusto paint. In that order, if I'm right. Yet buying the Rustoleum paint here is for one, not as its described in the states, or I'm not understanding the whole paint terminology quite enough yet. It seems theres 2 or 3 words to describe the same thing. Like, Oil-based, lacquer, enamel, Acrylic, etc.
The more I read and learn, the less confidence I have in any one method or product. Theres always 2 opposing opinions, and quite possibly one is wrong. Potentially very wrong, and following that 'wrong way' could cost a great deal of work and money.
Soft solid aluminum rivets, vs Hard
Epoxy type x vs type y
I'm happy with OEM materials and tractor paint, yet the fancy, expensive coating and materials are appealing. I mean, spend $300-$500 on a transom that will last 50 years, vs 10-20 years with proper care, for $150-$200 (Canadian $ remember). Do I care if my son has to redo my transom in 20 years? or will a properly cared for transom last a hundred years?
Do I Really need a Polyurethane epoxy primer and paint? Will it matter if I prep with sanding and vinegar vs Alumiprep and Alodine?
