Re: Please Describe The Pressure Test For Gear Case Seals
Do not exceed 15 psig, or you will for sure be replacing seals which may have been good. Also, LU MUST be drained first, or gear oil will mask results. Auto parts places have a manual vacuum pump for brake bleeding which works well for the vacuum test. Should have some pressure/vacuum after 45 minutes, and some leakdown is OK.
