kentuckydiesel
Thread starter- Joined
- Jul 11, 2012
- 48
Re: Please double check the speed/prop calculator info...does it seem right to you?
New results to share. I finally determined that one of my 19" pitch props WAS intermittently spinning on the hub under higher loads. It would hold for a while, then after a certain amount of stress, it would break loose. After it broke loose, I could drop rpms on that motor, then bring them back up, which would make it better...but not alot better. Determined this by swapping props from one engine to the other a couple different times.
Decided to go ahead and throw on a pair of 13 3/4"x15" props that came with the boat. (which are in fairly good shape aside from a few minor dings)
Ran down river, then back up...about 30min each way. I was seeing about 21mph at 5400rpm. (which is around 37% slip)
When I pushed it a little farther, it hopped up to about 26mph at 6100rpm (around 27% slip)
Turns out I need to do a little throttle cable adjustment because the port engine wanted to keep going past 6100rpm while the starboard engine just stayed there. Due to some slop in the cable, the throttle butterflies in the starboard engine are only opening about to about 3/4 throttle.
Anyway,
Although the trip was at a snail's pace, I feel like I got some solid and repeatable numbers to work with. I think because the starboard engine wanted to keep climbing, I could expect at least 6400-6500rpm WOT on both engines once I get the throttle cables sorted out.
If that's the case...since I'm looking for 5400-5500rpm top end with my wife and I in the boat, I need to go up by 5-7 inches of pitch, correct? So from a 15" prop, I would be looking at 20-22" pitch being ideal. I guess that puts me looking for a prop with 21" of pitch.
Looks like you guys were much more accurate on your speed expectations than those calculators I was trying to use.
BTW, Is it normal to get lower prop slip numbers as speed increases? I would have thought it would be the other way around.
Thanks!
-Phillip
Anyway,
Thanks!
-Phillip
