ChrisCraftJohnny
Thread starter- Joined
- Oct 7, 2009
- 187
I have some questions about running on muffs and about how, where and when the the water should flow.
Mercruiser 4.3L V6, Alpha 1 drive.
Ok, so the outdrive is down. Muffs installed. Water turned on. Start engine.
Engine at idle speed.
1. Water should be coming out at transom plate holes correct?
2. Some water should come out of the propeller exaust port correct?
3. When the thermostat opens at operating temperature (my case engine never gets over 150 Deg. on muffs) Water should flow out of holes even more correct?
4. What if you get exaust only out of the transom holes yet engine does not overheat?
Thanks. Please don't hi-jack my thread.
Johnny
Johnny
