Re: Please help...1969 Mercury 650 65hp outboard prop question
The "13" at the end of that number indicates the prop pitch, 13 inches in this case. About the right size for a 65hp to carry, and if the motor has been running well with this pitch that's what the replacement prop should be, too.
A typical size for this would be 13 X 13, the first # being the diameter of the prop, and the second # the pitch. Or, you might find a 13-1/4 x 13, even 13-1/2 x 13. If I recall, the largest diameter your gearcase will take is a 14".
In all of the above cases the 2nd # indicates the pitch, with the diameter varying a bit.
I don't expect that this is being used in a high-speed application, so any of those diameters would work well. The motor will "spin up" a bit faster with a smaller diameter prop, and I expect you'll find that the "13 x 13" is a pretty common size. The larger-diameter props would be suitable for pushing heavy loads and will actually be more efficient at doing so than a smaller-diameter prop.
Note that many of the newer replacement props have integral thrust hubs. Your propeller will likely have a removable hub that fits up against the beveled portion of the prop shaft, and also fits into a 'shoulder' in the prop. You may even have a removable thrust hub on the prop nut side of the old prop.
New props will most likely have a built-in thrust hub on the prop nut side. And the hub on the gearcase side of the prop will be built-in, with a flat surface.
You'll need a flat thrust washer which will bear against that beveled edge on the propshaft, and sit flat on the propeller's integral hub. These are commonly available and whoever you're buying a prop from should have one.
Hope that all makes sense!
You should even be able to look up propellers in the retail section of this site.
Here's a likely match I found at the Tacoma Propeller site after a Google search:
http://www.tacomapropeller.com/6433...-AL-Match-Propeller-Hub-kit-not-required.html
HTH and let us know how that works out for you.............ed
