Please help 1975 mercury 200 20hp
Thrawn5499
Ok i got it all back together. Hooked a water hose and clamp over the water intake. Started it up. No water peeing out. So i shut it right back off.
Not sure if i got the water pump hose hooked up correctly or maybe the impeller is turned over 180 degrees, if that even matters. I know it peed good when i got it. Ot sure what is going on now. Might just be my hose attachment fits too loose. It wasn’t really connected.
I have read somewhere that it has to warm up a little but before it lets the water pee out. Anyone know what i can try? I made sure to get the little key back on when changing the impeller. So it should be good there.
jimmbo
The grommet in the water pump where the pipe fits was good?
Thrawn5499
Idk, i thought everything looked good? But if it was missing i might not have noticed.
I ditched the muffs and borrowed a 55gal can from my neighbor. It pees perfect
Thrawn5499
If it pees while in a barrel, it has to be working.
My thoughts too. I didn’t test it that way at first because I didn’t have one. So i posted the question. While i was back out looking it over my neighbor walked over with his barrel.
