GreenRiverPirate
Thread starter- Joined
- Aug 20, 2011
- 14
I have a 1982 9.9 Johnson. I have been messing with this thing for a week and needles to say I'm frustrated to say the least. http://forums.iboats.com/images/smilies/facepalm.gif This engine has very little time on it. My friend gave it to me after he hit something and broke the bearing carrier. (The part that separates the exhaust from the gear oil) I had it welded back together and re-assembled. When I took it out on the river it skipped under load, by skipped I mean it continues to pull but it feels like you shift it into neutral and back into gear in a split second. Like side-stepping a clutch in a stick shift while it's under load. I just wonder if the prop could cause this symptom. http://forums.iboats.com/images/smilies/confused.gif I have completely gone through the lower unit and everything is just as it should be. The shift rod is properly adjusted. everything has been checked and double checked. I've had this thing apart so many times I think I could tear it down and rebuild it faster than a nascar pit-crew can service a car. lol
Model # J10RCNS
Model # J10RCNS
