Valsar
Thread starter- Joined
- Apr 21, 2019
- 13
Having trouble with a 1989 evinrude 50 hp outboard Model CE50BELCUD
Problem 1: engine chokes out, ball is soft, will idle for a bit then quit and require choke and full throttle many times before it goes for a bit.
took apart the carb, cleaned it, replaced a fuel hose since it was rotted, and re attached a vacuum hose that was disconnected on the bottom carb.
upon reassembling and trying to see if any results came, it still chokes out, but now the horn sounds from the throttle. I then looked to see it any wires were damaged and saw the rectifier wire fried. Fixing this I'm still having these issues.
what can this be ??
what can this be ??
