First of hall: Sorry for my bad english
I try to explain the problem in the hope to make it in comprehensible way dates my limited mechanical abilities.
The motor in issue is johnoson a 40 HP year 2000 The found problem is following: the engine runs well, but when I insert the march in order to be left over, the accelerator jams to half. The boat leaves, but the turns of the motor do not exceed the 3000 Acting on the accelerator directly on the motor to crowds, the motor turns well. Initially I had thought to an breakdown in the cable that goes to the motor, for which I have supplied to take apart finding it that all it was ok. Acting on the motor, i noticed that the cable of the accelerator commands (with its movement) not only the opening of the valves of the carburetors, but also something that becomes part under what creed is called flies (?) (that is that enormous wheel bite that is looked at as soon as removed the cover of the engine).
IS this connection that seems blocked and prevents to the accelerator to be left over completely.
Issue n°1: what is the funzion of this connection?
Eliminating such connection I succeed to make to advance the accelerator completely, but the engine does not reach the maximum turns.
Restoring this connection the accelerator jams of new to half road.
In any case whichever help and suggestion are very accept
Thanks to all
Thanks to all
