please help give me some info
spicerak
i have a 150 evinrude xp power tilt works from front not from switch in back.i have installed a new switch but not the same one that i had,the one i had has three prong and the one i bought has like six do i need the same one.also is there a way to cut the wires and touch one at a time to check them. i cant get it to work At THE SWITCH IM GOING CRAZY. do those wires in the back have power to them they should i would think .also the compression is about 90 form each head do i need the take all the plugs out to check them or one at a time.the left side plugs seem to get dry looking when the right side looks side they have some oil on them what u think is up with that
jtexas
Re: please help give me some info
your six-terminal switch should work, but you just use half of it, either side, doesn't matter.
get yourself an autoranging digital multimeter (walmart has one in automotive, about $25, not the best but good enough).
to test your old switch, set your multimeter to test for continuity, touch one probe to the middle post and the other to the upper post. push the switch down, a tone should sound. move the probe from upper to lower post and push the switch up, a tone should sound. If you get this result then the switch is ok.
Test the wires: set your multimeter to VDC. Notice how the readout "floats" when the probes aren't touching anything -- that's what it looks like when there's no connection. Touch the red probe to battery (+) and black to battery (-) -- if it's fully charged you should get 12.65 or more. That's your "open circuit" battery voltage.
Now move the red probe to the wire that goes on the middle post of the switch. If it won't reach, use a spare length of wire to make the connection. Should get about the same, a little bit under, the battery open circuit voltage. Any other result means a wiring fault.
All plugs out for compression test, disable spark by pulling the emergency lanyard.
"left side" is that left side of the boat facing forward (port), or left side of the engine looking at it from inside the boat (starboard)? Plugs should have a light coating of oil after idling. Are the port bank plugs the same color as the starboard?
spicerak
hey thanks it was the red wire broke in a splice that i cpouldnt see.i just did a decarb and the plugs look good after that but when i run it for a while it seems like the plugs on the right side from boat seem to get dry and carbon ish i looked at left side and they have a little oil on them that looks good to me shouldnt the others look the same.what would be doing that.also when i first use the boat it runs fine but later in the day when i try to go i need to give it gas and choke at the same time so it dosent bog out is that the carbs or engine problems thanks for the help
