Please help Identify my Motor
AzogNewOrleans
Hello, just picked up a Johnson 6 Seahorse, at least according to the cover.
Model Number is CD16. I need to order a manual, find the fuel/oil ratio and also prop info, Is the shear pin only held in by the plastic cap? I searched the tables with no success.
Thanks for your help, Dan
jay_merrill
Re: Please help Identify my Motor
Nevermind - see my post in the other thread.
AzogNewOrleans
Thank you very much. I needed that info for the lower unit but I have discovered the top end is newer. I need to identify the motor section.
Start puller is not on top of the motor buy cord enters middle of case face and winds around a spool that engages contact gears at the flywheel.
Will post pics when battery charges on camera.
Thank You
