Mechengineer03
- Joined
- Jul 30, 2010
- 16
I have a Stratos 201XL with a Johnson GT 200, while out on the lake today I was cruising at about 40-45MPH (about 4000 RPM's) and all of a sudden it was like I thru it in neutral, the prop stopped turning and now will not go into gear at all, the motor is still running fine but no matter where I put the gear lever it will not engage the prop, whether it be forward or reverse it is all the same, also after I pulled the boat out of the water on the trailer I tried it again and when it is in forward position you can turn the prop with your hand just like you can when it is in neutral.
PLEASE HELP and thanks in advance to all who can tell me what to do here.
