Please Help Me Identify My Johnson Seahorse 15
curtisj
Is it possible to identify your engine year with just a serial number? My Johnson Seahorse 15 came without the I.D. plate. There is a number stamped on the transom mount iam assuming this is the serial number can you identify the year with this alone? is there another spot where the model number is stamped? Please Help ASAP. Thanx
Xcusme
Re: Please Help Me Identify My Johnson Seahorse 15
Welcome to iboats!
If the transom plate is gone, remove motor cover and look on the power head for a quarter sized alum. disc. On the disc you'll have the model and serial numbers.
samo_ott
Post what you can find.
curtisj
I found this number on the transom mount 309738-2
and I found this number on a part near the flywheel 320819
Please Help
curtisj
By The Way Thanks For Replying So Quickly. You Guys Are Awesome.
curtisj
I found these numbers on the sides of the powerhead 318928-1 1-322404
I found this number on top of the powerhead 388184-3
I found these number on some plastic housing attached to the back of the powerhead CD2 581926
Hope this helps
Xcusme
Those numbers sound like casting numbers....no help
The CD2 581926 is the ignition module, so your motor isn't THAT old...
If you can't find a silver disc on the power head, can you post a picture of your motor??
BTW, here's a pic of silver disc "Welsh Plug" courtesy of Tashasdaddy
curtisj
Will these pics help. If not let me knowhat to capture:
ezeke
Does it look like the one in the thumbnail attached?
If not, what color is it?
curtisj
heres one
curtisj
Heres Another. Does anyone know the year and model
ezeke
Well, the motor may very well be from 1977.
You can go to the parts store and compare the parts and their numbers to be sure. http://shop.evinrude.com/
Just click the picture of the parts diagram, then navigate to your motor.
BTW, I have edited your photo to show where the ID plate should be. Could it be painted over?
Chinewalker
Definitely looks like 1977/1978 era. By 1979 they had the black encased coils in place of the ones with the exposed laminates...
- Scott
curtisj
Is it a good year. I just got it. It runs but iam gonna have to take it in and get tuned up for sure. Is it worth the money and time or should i just buy a new one. Do they perform well?
wbeaton
Its a great motor. Shouldn't take much to tune it up. Replace the water pump impeller.
dodgeramsst2003
I have an identical 77 15hp for a trolling motor on my boat. I bought it this spring. First time out I lost the powerpack. Probably just a fluke, it was cheap too at under $60. The thing runs like a top, and starts easy. parts are still available, so I would hang on to it, or if you want to give it away, PM me and I'll send you my address :D
Chris
curtisj
Iam having problems starting it. It sounds like it wants to start and i know it runs. What could be the dilemma? It has new spark plugs too.
samo_ott
Dirty carb, low compression or weak spark are the 3 things that will make it hard to start.
curtisj
Thanks Steve. Are cleaning carbs tricky? Is it possible for plugs to be bad when they look shiny and theres no carbon build up present? And How sure are you guys that its a 77' seahorse 15? Would it be safe to buy a manual? And EZEKE the nameplate is completely gone.
samo_ott
I don't know my modern years very well so don't look at me for the year.
as for the carb, they're easy to clean, buy a carb kit ($30 or so) and replace all the gaskets and key parts, use carb cleaner and blow it all out with air. The hard part on those engines is the re and re of the carb.
