I took apart my 1977 evinrude 6hp to change out the impeller and I found this roll pin/key on the drive shaft towards the top about 2 inches below the splines on the drive shaft. I dont know what it's purpose is, but it was sticking out on either side of the driveshaft a good 1/16". There was also some metal shavings around it. I think it may have been scraping the inside of the exhaust housing causing those shavings. Anyway, if no one can tell me what the purpose of it is, I am going to put the lower unit back on and forget that rollpin. Thanks!! as always.
