I have a 2005 Merc 115, 4-stroke. It appears to have no more than 100 hours of use when I bought it a year ago. Since then I have put about 30 hours on it. When I first got it the best it made was 35 mph at 5000 rpm. It gradually dropped down to 3000 rpm. Today, after I replaced oil, new lower gear lube, new water separator, new fuel filter, checked and cleaned spark plugs, it would hit 6000 rpm on land but once in water it would not go past 1200 rpm and coughed all the way. I put Sea Foam in the gas tank and that did not do anything.
My neighbor thinks that the idle limiting sensor has gone bad, which would not allow the rpm to go up. I looked up the manual and could not find that sensor he was talking about.
What should I look into? I just cannot believe having problem with an engine which hardly sees 200 hours of use. Thanks in advance for your advices.
Seapro1
Seapro1
