Please help with the serial number.
KIRASIR
Hi,<br /><br />I just recently bought a boat that came with an 80hp Merc motor. I believe the year is about 1979-1980. The problem is that the tag is missing, and I have no idea what the serial number for this motor is.<br /><br />Motor 1 <br />Motor 2 <br />Motor 3 <br /><br />Thanks<br /><br />Serge<br /><br />Thanks<br /><br />Serge
KIRASIR
Re: Please help with the serial number.
oops, signed the previous post twice. :(
Waterbugtoo
Serial number is located on the port side top of the swivel/tilt bracket on a silver colored tag. Basically from the inside of the boat looking towards motor......look on the right side just under your steering link arm.<br /><br />
KIRASIR
Thanks, but that was the first place I looked at. No tag there. Is there any other way to determine the serial number? From the inside perhaps?<br /><br />Thanks<br /><br />Serge
rickdb1boat
Try looking around for a Welsh Plug on the Engine. Should be a Silver Plug that is about the size of a quarter. Numbers should be on there or stamped directly to the head somewhere. It will be an 8 letter/number value.
Chinewalker
Hi Serge,<br /> The decals date it as a 1980/1981 model, which fit with your guess. They likely didn't change too much between those model years, so any manuals you need are probably going to cover both years.<br />- Scott
