dave69larson
Thread starter- Joined
- Aug 17, 2009
- 6
Hi first I am new to this forum, I have a 1969 larson 18ft 120hp inboard. I recently recieved as a gift. I have a couple of different ?'s
First last time I had it out with tow people in, it ran fine got up on plane farily quick and did about 30mph with a 3 blade 15 pitch prop. Then after a bit went back and pick up a total of four people and the boat took a bit longer to plain but it did. After fishing for a bit we went to take off but the boat would only rev up to 3000 rpm and felt like the boat was too havy in the back end or the motor was bogging.
So questions are is a 3 blade 15 pitch good enough to run on there or should I be going with something bigger, at wot it will rev to 5000 rpm but I only took to 4500 when I was givener. I am guessing that it should run around 4500 rpm at wot.
2nd I did a compression test and the cylinders ran between 105 and 80 at the lowest, is that sufficent to create enough power?
one other question is I was looking at the bilge area and the front of the bilge area is open to the bottom of the boat. There is about a 4 inch drop to the bottom of the boat . Should that be open to allow water at the front of the boat to come back or should it be sealed.
Any help would be great and as fast as possible my summer is going fast.
