Re: Please help!!
welp..you can purchase a dva adapter for you multimeter then go to cdielectronics.com/troubleshooting, find your engine and it'll give you the values you should see for each component...2 things to keep in mind... voltage coming into the powerpack from the black/yellow wire can damage the powepack < cdi gives a max. value for this >, the sensor < trigger> and power coil under the f/w supply the signal/primary voltage for each plug, so, if only one plug is firing the coil, pp or some other wiring problem is suspect, if neither plug is firing you've got the grounding < kill switch>, trigger, power coil, pp, and a possible wiring problem still in play. That's why you need to determine if one, both, neither plugwire is delivering enough voltage to jump a 7/16" air gap.
