Please, I need a favor
petryshyn
Re: Please, I need a favor
woywoyboy, I thought you put the bite on em'.<br />I'm shocked and appalled......just kidding!!<br />Thanx for lookin' man....Just hope I don't keep you up at night with my noisy gear box!! (Our prime walleye fishing is probably when you're still in bed!)<br /><br />
Peter O
Hey ther schematic, can you email me @ plobrien@shaw.ca I have a question about your peterborough and where you fish walleye!<br /><br />thanks
clanton
The number is 7.511 inches US, number stamped on bar, new style tool. You need .020 US between bar and bearing housing. You owe me.
petryshyn
clanton, there is no doubt in my mind.......You are the 'MAN'. Yes.....I owe you big time!!!<br /><br /> :) :) :)
speed29668
Can someone explain how shimming works and where they are place for the pinion gear? I have a 1974 75 HP Chrysler. I removed the driveshaft to replace a seal and the upper bearing. When torquing down the original pinion gear nut on the end of the shaft to 85 ft-lbs., as the manual calls for, the drive shaft is extrememly tight and I can barely turn it by hand. When removing the nut, it didn't seem like it was tightened to 85 ft-lbs. All races are properly seated. The driveshaft operated fine before disassembling. The manual calls for a new nut. Does the nut have some sort of "one time" locking feature that requires a larger torque to tighten? Thanks for reading.
