Please look at photo, 58 rude 10 hp, advise
kodibass
Please look at the two photos of my 58 rude 10 hp, I'm pointing at a slot in the magneto base, as you can see by the position of the flywheel key between the 2 photos the base moves, my question is does this slot serve a purpose and does it line up with something? I think I can mount the magneto plate with the slot forward or to the rear? sorry I know this is not very clear, but I hope you can get what I'm asking Thanks.
kodibass
PHOTO This is a cheap but nice paint, 58 rude 10 hp
This is a cover from my 58 rude 10 hp, the paint on the very top portion is from a local hardware store 6.00 a can its metallic cobalt blue, I'm not doing a restoration just fixing it up for runner / user. I found the motor laying in a guys yard he said it had been there for at least 15 years, so far every things been ok on it, Which is amazing I live on Kodiak Island Ak, very salty here, 15++ Alaskan winters laying outside on the ground less than 200 yards from the beach, started up and ran after a points / carb clean. Just got all the new ignition parts, carb kit, impeller etc. in this week.. So if you want a nice paint for cheap, this is a pretty nice choice. cheers!
5150abf
Re: PHOTO This is a cheap but nice paint, 58 rude 10 hp
Not bad for a spray bomb, I actually used a spray can for my engine but I stripped it down and used primer and then finished with real 2 part auto clear so I was going more for restore but yours looks pretty good.
Chinewalker
Re: Please look at photo, 58 rude 10 hp, advise
I've never been sure why the slot is there. It's not there on all of the retainer rings. I've never paid any attention to it and have never had a problem....
1946Zephyr
Coolness. I have a 1958 Evinrude Fisherman that looks almost that nice. I have to go through it and replace the crank and rods in it though, but it'll be a nice motor when I'm done.
Nice job on the paint.
1946Zephyr
Yea, I agree. I haven't yet seen a purpose for it either. I know I seen that slot on my later model 40's and 35's as well. They probably had some sort of plan for it, that never materialized.
Mas
I like the color!
Mas
kbait
When I've seen 'em, the slot is usually to the rear, so that's how I re-assemble. Probably makes no difference either way though..
tmcalavy
Nice work...I finish mine with several coats of Rustoleum clear enamel.
F_R
Honorary Supreme Mariner
As far as I can figure out, the slot was for manufacturing purposes, to hold it in some sort of fixture for machining. Whatever, it serves absolutely no purpose now. Ignore it.
nwcove
is it my bad eyes....or does the flywheel key look a bit "beat up"....and maybe need replacing?
kfa4303
Banned
yeah it does look kinda chewed up :/ I'd probably replace it just to be safe. You should be able to get one from almost any OMC dealer, or maybe right here at iboats, or off of e-bay.
nwcove
looks like it might be cheap preventative maintenance!
kodibass
I checked the key it looks allot worse in the photo than it is mostly yuk & dirt, but I am going to replace it as well, thanks for the info on the slot!, soon as she is all back together I post a pic.
ultra353
Heres my rattle can paint job
kodibass
ultra353, is that omc paint?, I have not done the lower leg on mine yet, waiting till after I do the water pump, That is about the color I want, yours looks great, do you have a paint name or #
ultra353
Hi kodibass, thanks, its plasti-kote truck & sport utility acrylic lacquer. If i remember correctly ( i don`t have the can anymore) # 1568. I think its a ford vehicle color. Here is a pic of Plasti-kote #1586 on my evinrude 25hp. Its a bit lighter and a bit more metallic in it.
