beason
- Joined
- Mar 15, 2011
- 338
I run 100% salt water, and i know its hard on the engine, even with regular flushings. I was under the influence that a closed system required hull modification for the heat exchanger, but have recently found this is not the case, so it looks like something i could install myself.
I have a Chaparall 220 ssi with the Volvo Penta 5.0L and the DP outdrive.
so here are my questions.
1 is it worth swapping on an engine that has already been ran in the salt for a while? would there be a significant savings on replacing parts, or after run maintenance to warrant the swap?
2 is it an easy install? with my basic understanding, you put the heat exchanger inline between the raw pump and the circulation pump. separating them into two systems.
3 it seems the exhaust is still raw cooled. with the risers and manis being a big investment, i was hoping to include exhaust cooling in the system to help preserve them. is there a way to do this?
4 i would still need to flush the exchanger and exhaust correct? would the exchanger hold up to salt water for long term?
Thanks in advance.
Thanks in advance.
