jmarcos2000_2000
- Joined
- Jun 5, 2007
- 6
i have the johnson repair book, but the engine picture are diferent of my engine. please help me where is the thermostat in engine johnson 140 hp 1982. thankyou
Sorry, I have no pictures, but the cylinder heads are the two large rectangular parts of the engine where the sparkplugs screw into. With the motor cover off and standing behind the motor, in between the cylinder heads is a large rounded cover. The tell-tale tube or pee tube comes from this cover. Otherwise it is fairly smooth. Just below this cover is a smaller rectangular cover about 6 inches long horizontally and 2 inches vertically. There will be a rubber hose about 1 inch in diameter coming from each end of this smaller cover and going to each of the cylinder heads. The thermostats are under this cover. It is difficult to remove and even more difficult to reinstall the thermostats and cover with the powerhead (engine block) still mounted because of the lower engine cowling (the part that has the 2 rear cowling locking handles). It can be done, but you must remove the 4 mounting screws that hold the lower cover in place. You cannot remove the lower cover without removing the powerhead. But, you can reposition it enough to access the bolts holding the thermostat cover. Watch out when you remove the thermostat cover. There are 2 spring loaded by-pass valves that will fly apart. Don't lose the parts. To put back together you will have to hold the springs and thermostats in place with plastic wire ties or something similar that can be removed once the cover bolts have been started. It will be very helpful to have a 1/4" socket set with a flex drive or universal drive adaptor.thanks joe revee but i'm no undertand,because i need picture or diagrams. is my first boat and i don't know parts names.
