plug R43T same as MR43T?
int76
I'm in the process of changing the spark plugs on my 3.0 Mercruiser and all the parts store carries is a AC Delco R34T and not the recommended MR43T, are these plugs the same? I've already tried the Autolite 145s and they made it run terrible. Any other suggestions for plugs? Thanks-Josh
bruceb58
Re: plug R43T same as MR43T?
MR43T are the same except that the metal is more corrosion resistant.
Ayuh,... The R43T is a Steel bodied plug that Rusts, Badly...
The MR43T is an Alloyed bodied plug that doesn't Rust itself in...
Gary H NC
Try Napa if you need them fast or Rockauto.com for the best price...
PitchFork
I just purchased 8 of them from NAPA at $2.07 a piece. As a side note stay with AC Delco MR43T. If you go to AutoZone they will try to give you some other brand like spit fire plugs that cost twice as much and they are not the recommended ones in your manual. Make sure to gap them correctly as mine came at 0.040" and needed to be 0.035".
fat fanny
I had the same issue last year and could not find the mr43t's anywhere Napa claims A/C discontinued them? But ona second note I used to be able to get all my marine parts from my local Napa and as of last summer they claimed to have discontinued the access of marine grade parts? and don't even have the parts catalog anymore whats with that?
havasuboatman
Ensign
M: marine
R: resistor
4: 14 mm thread
3: heat range
T: tapered seat.
zbnutcase
Autolites will rust like a banshee also!!! 'nutcase
