Plug wires??
Boater1010
Can I use standard plug wires for a tractor? the local farm supply store sells wire kits for a 4cyl tractor for $12. Also does it matter if I use 7mm or 8mm wire? I have a 56evinrude 30hp I want to replace wires on.
thanks
nwcove
Re: Plug wires??
If the wire is metallic core its ok. But you do realize that the wires on your motor could be a lot longer than the wires that come in the kit! (!dont quote me on this, but the wire for number 2 cyl could be 3 ft long or longer) Also 7mm is the standard size. You may not be able to get 8mm to fit in the coils.
oldcatamount
Re: Plug wires??
7mm is the most often used but as long as it's a quality grade of spark plug wire it shouldn't make any difference.
