plugged deflector hose?
jasper60103
Noticed one of the deflector hoses is plugged? Looks like a piece of plastic shoved in there intentionally. Is water suppose to flow through the deflector hose? I won't worry about it if it doesn't affect anything.
mikesea
Re: plugged deflector hose?
no ,it wont affect it,they are not supposed to have water pass thru,they deflect water from the side,wh the plastic is there ???? who knows.Do you have a perticular problem?? why did you pull the head,dont forget NEW gasket and torque the bolts
ezeke
Probably there because it's the wrong hose. The correct one has an OD of 3/8 and ID of 1/8, like the one across from it. Doesn't matter as long as it does not move.
