yheap, making the engine actually shut down! <br />but i found a little trick to cleaning the plugs with a drill and a piece of fine sand paper on the other end. works wonders as you can see. <br />the 2 plugs on the right are autolites (wich i dont recomend using) and the other ones are NGK buhx and were just as bad if not worst. <br />
<br /><br />i decarbed last season but i will try it againg. i can see carbon build up trough the spark plug hole. ama decarb the eng but i dont know what else to try. i got the carb screw 1 1/4 turns out from lightly seated.
(89 force 50, new f. pump diaghfram and lines. clean carb)
