Motor is 1997 120Hp Force, Exhausts through hub.<br />Ive had moisture in the engine causing the plugs to rust (#1&2). Took to the shop, advised them of the problem. They did a compression which tested all OK so they left it up to me advise them what to do!. (I thought they were the professionals!) Asked them to do a head gasket as I though this was the obvious thing to do and they said there seemed to be a bit of water tracking from the exhaust plate gasket. Had head gasket re placed, side plate gasket replaced. $400 later, seemed to fix the problem Have been for a run last week (Motor ran fine) and re checked plugs this week. I now have rust forming on #1,2 &4.<br />Have pull carbs off and removed Reed Valves blocks all OK. There is no rust forming on the Crank etc.<br />Boat is garaged. <br />Has anyone got any ideas what the problem may be? <br />Thanks<br />Alan, Christchurch, New Zealand
