Kevlar7R
Thread starter- Joined
- Jun 30, 2011
- 18
I have a private dock on a navigable waterway, and I am looking to set it up to be fully self sufficient. I haven't found much info in searches, so, I thought I'd start a thread. 30amp shore power and water are pretty obvious and easy. I'd also like to fuel and pump out my boat at my own dock. For reference my dock is about 50' from shore to the end, and the land level sits about 18' above mean tide level. For fuel, this is great; I can use the 18' of head to pump the fuel. My tenative plan is to get an old home heating oil tank, and place it at the top of the hill, and plumb down to a filler valve at the dock. What to plumb with is the question. My current idea is pex tubing and sharkbite fittings. Thoughts? Had any one run fuel through pex? Initial research seems to show that it shouldn't react. I don't need to pump fast, so 1/2" tubing should be fine. I can use a basic brass ball valve at the bottom, since I have a whistler on my vent, I don't need an auto shut off valve. Waste... Now that's an issue. I need to get it off the boat, and move it about 150' with 18' of head to get it to my septic tank. The last 75' or so are down hill, so not a problem there. I could get the waste out of the boat with an on-board mascerator, but what then? Commercial pump out pumps are prohibitively expensive. I'm open to ideas here. Let's hear your thoughts!
