R Socey
Thread starter- Joined
- Jan 9, 2011
- 501
I want to install a Jabsco 7gpm 12v washdown that tees at the console so there are two spray heads. I do alot of chumming, and bait fishing at night. I want the port side to deal with their mess, and the starboard to do the same. What size intake thru hole should I make? Where should I make it -bottom or transom? What size sea **** should I use? Also, I want to run a disperate continuos baitwell system that utilizes a shurflo pro baitmaster pump. What size hole? Where? What size sea ****? How big do I need the overflow holes on the baitwell to be? I want two of them - one on either side to compensate for list - to join inside the console, and dump out the side of the boat? 24'8" cc Thanks guys!
