sogood
- Joined
- May 11, 2016
- 361
I'm in the process of refurbing a 1990 Wellcraft 250 Sportsman and was looking at replacing some of the hoses on the toilet/head set up. So, I began the process of identifying and tracing the existing hoses. I have identified much of what is there and the set up is such that there is a waste holding tank as well as a direct flow to the outside, which seems to be controlled via a "Y" valve. The water supply itself comes from outside also and both inlet and outlet are controlled by sea cocks.
As I'm at sea all the time, I'm wondering can I simplify matters and eliminate the holding tank altogether. There is a "Waste" cap on the gunwale alongside the "Gas" cap, which I'm assuming is for draining/syphoning the waste out. Is this right?
Any thoughts, suggestions, best approach etc. much appreciated.
