Plywood floor replacement...Questions
jonny rotten
Making some pretty good progress. Got the floor out dry fit 3/4 ply cut out some foam and then sealed the plywood
Next step attach plywood to hull
jbcurt00
Ignoring questions that needed to be answered before advice can be given isnt the same as no answers.
Yes, you're mixing aluminum & fiberglass methods, possibly to your own detriment.
Same advice was given in other topic: do it right or dont do it
You've chosen the wrong process and proceeded anyway.
Its your boat, do as you see fit. But when done counter to recommended methods, typically, topics get fewer responses since the advice is being ignored.
KJM
That wood is now full of linseed oil. I doubt that resin will adhere to that. How are you going to join the floor to the hull?
jonny rotten
Lock tight marine or 5200. Both of which are rated for deck to hull joints. Most likely lock tight. Now I'm hoping it bonds to the linseed oil. Waiting a week for the sealant on the wood to dry before installing on the boat
jbcurt00
Insufficient plan
jonny rotten
I called 3M after being told the linseed oil and resin could be an issue which I didn't know.They confirmed and said to sand it down to Bare wood and run a test strip to see if it bonds. It seems like that might work after sanding it. I'm going to try to fiberglass it instead of using the 5200. Hoping for the best
ShoestringMariner
You’re using the OTF method. Or Old Timers Formula homemade wood preservative. Designed to be topcoated with spar varnish etc. You might want to start over with fresh ply and save the OTF ply for another project
or if you’re mechanically fastening it, simply finish with Spar and cover it with nautolex.
jonny rotten
Right, I found out about it here. Sounded like the wood would last a long time with this method so I did it. Aside from my possible bonding issue with the linseed oil I still not sure what the problem is yet it's been dumped on here.
The plan was Seal it, install it, roll out spar after installed and carpet I read in another forum it will and did bond permanently to other peoples boat with dried linseed so I'm hoping for the best
jonny rotten
Can you use polyester resin with either a glass strip to bond deck to hull. Or make peanut butter out of polyester resin for a deck/hull bond instead of epoxy?
ShoestringMariner
That’s what I did with my transom and will be doing with my floors. But I’m mechanically fastening in an aluminum boat. Are your floors supposed to be glassed in? Or are they non structural? I don’t know glass boats
GSPLures
Fiberglass boat decks need to be fiberglassed in they are a structural member of the hull. The method being used is for and should only be used on aluminum boats.
KJM
Yes you can. Poly resin is what most people use. Most do the PB to fill any gaps and make a curved join and then put glass over that.
jonny rotten
Great. Does it need to be 1708 cloth or will any cloth work? Doesn't matter what it looks like it's getting carpet over it Will one layer of cloth be enough or do I need more layers?
jonny rotten
I'm going to fiberglass it to the hull and fiberglass all seams in plywood
todhunter
Canoeist
Use PB as a "glue" to attach the deck to the stringers and the edges to the hull. Also use PB to make fillets for smooth transitions between the deck and the hull. Ideally while the PB is still wet, lay 2 layers of fiberglass tabbing across the deck/hull joint - the first layer cut to strips ~6" wide, the 2nd layer cu the strips to ~10" wide. I recommend 1708, but you could probably use woven roving or something else structural if you want. I would not use CSM for structural repairs (and this is a structural repair).
For joints/seams in the deck, I also put some PB in the joint. I laid glass over my entire deck when done, but if you aren't going to do that, you may want to at least lay a strip of glass over the joint, as you stated.
jonny rotten
Thanks for the detailed information. When you say 2 layers does that mean one layer, wait to dry and do the process again or double up on the fiberglass and do it all at once?
todhunter
Canoeist
Lay the PB in and make a fillet. While the PB is still wet, wet out and lay down the ~6" wide strip of 1708 with ~3" on the deck and ~3" on the hull. While that's still wet, wet out and lay down the ~10" wide strip of 1708.
You have to work in sections to keep everything wet. If you try to lay all your PB down at once, then come back and lay all your 6" wide strips down, etc., you likely won't have enough time before the resin starts to kick. I did strips as wide as my roll (50"). Ideally you should make it where the seams between the 6" strips and 10" strips don't line up. I started by piping PB for 75", then laying a 25" x 6" strip and a 50" x 6" strip to cover the PB, then a 10" x 50" strip over that. After that, you just build onto the end using 50" strips - lay PB, lay one strip of 6", then one strip of 10", then repeat.
jonny rotten
OK so the PB and the fiberglass all get's done at the same time wet. I thought PB one day and the rest another day.
So to confirm:
PB
Apply the fiberglass resin with hardener over PB while wet
Apply mutable layers of glass on resin (different widths)
Tap more resin over glass till it soaks through
Entire process at the same time assuming short lengths so it doesn't setup while doing it.
Is that correct?
If so and the PB starts to harden while mixing and messing with the fiberglass does it matter?
todhunter
Canoeist
I mean you can let the PB set, and you can let the first layer of glass set, but you may need to go back over it with some sand paper to knock down any hairs or high spots. I like laying things wet on wet when possible because it drastically reduces air bubbles from uneven sub-surface, since the sub-surface is still liquid it lays down much nicer. By no means do you need to use this method though. If the PB starts to kick, you'll know it. If you are still putting it down, it won't meld with the rest of it as well. If it's already down, it won't feel as soft and moldable...more like a jelly that rapidly turns into a rock, haha.
jonny rotten
Great. I've never done any fiberglass work. Learning as I go. I'll do it your way
