Daniel1947
- Joined
- Sep 22, 2010
- 267
So right gm280. That was kind of what I was trying to get to with my post. Where there is a will, there is always a way. The web/internet is a wonderful place, but it is also filled with much BS. That was kind of where I was going. When one calls the manufacturer, as I did in the case of Arauco, and then contact venders that they say "carries" their product, or you go to a Lowes or H.D. website, and then get a run around there, it can get kind of frustrating to a beginner. I originally stayed away from even looking for marine grade because of the "you don't need marine grade," "ACX or BCX will work fine," or "fine Arauco, H.D. carries it. Then I find it at 2 lumber yards locally. My main recommendation is read the threads, and research locally. Case in point...resin...yes I could have purchased it online, from out of state, paid freight and hazmat; but with a little "research" I found a local supplier...5 gals of poly resin $108, hardener $5, 5 gals of Acetone $60, foam 1 gal of each A & B $75 total. What I saved on the resins etc., more than offset the additional cost of marine grade. If I had not found the marine grade within 75 miles or so, I would have gone with the next "best" I could find.
Once again: The information supplied on this forum from you and all the other knowledgeable members is invaluable...priceless. But the person doing the repair needs to be also willing to do some of the work "RESEARCH" their selves. There are more ways to do a project and not all of them are wrong as we have all discovered.
My thanks to all that have helped me,
