Plywood Galvanized Screws
mercury713
Re: Plywood Galvanized Screws
Cool Idea
But will put maybe 50 more Pounds on Boat.
When crossing Channel I place Life Jacket on and hold on... gets calmer 1/4 out.
Sometimes I let a big boat go threw and he brakes the waves for me.
My last boat was 12f by 4 18inchs high and was kinda scary going threw... Almost flipped coming down 6feet waves.
If the winds pickup get back to dock fast.
I want to make this one 15feet to help me out, found some 16feet 4x2's and got them cut in half last night.
Case450
lmao...a thousand deck screws for a boat thats 15' long and 4' wide? The screws'll almost weigh as much as the wood....talk about overkill....you'd be surprised how much lateral holding force there is with 1 screw...almost a square foot
mercury713
A question maybe someone can help with.
I made frame 44 inches wide.
Bracing floor, What distance do I place between braces?
1/2 plywood will be used.
My Camera batteries let go there 1.2volts as normal batts are 1.3volts. tryed 1.3 and even cheap ones and no go :(
mercury713
Case450 I was just guessing... I'm going to place them about 1 1/2" apart. adds up fast.
Yacht Dr.
Merc ..
Are you making a mold/plug ? or are you just fastening..
1 1/2" apart is making swiss cheese out of your bonds..
YD.
mercury713
Yacht Dr
Just fasting. Yes maybe a inch.(thought to fast)
I was wondering if I could vanish my boat instead of painting?
Will it hold up well in salt water?
Started bending the front 2x2 lips. Placed a wet towel around them with weight.
fishrdan
Check out this place for SS or bronze screws, they were the cheapest place I found online when I was doing my project.
fasteners
mercury713
fasteners
Shipping would kill me aswell... id need close to 20pounds plus I already started framing with deck screws.
I don't want to invest 200$ in screws.
Boat might cost me 300... I would of bought one for about 600 but 20inch transoms are hard to find here.
JAFO1
How's your build coming Merc?
mercury713
JAFO1 Hi there.
Almost got all the framing done.
Spruce wood is hard to bend , got them to bend about 9 inches.
I decided to buy a 10x2 board and bend the top lip to meet the bottom lip and place 10x2 on 45degree angle.
I bought 1.2volt batteries for Camera but forgot them at GF place, Il try and get pictures in a day or two.
Front will look something like this.
http://s156.photobucket.com/albums/t4/domains/?action=view&current=thissd.png
JAFO1
JAFO1 Hi there.
Get the pictures posted up! I'm interested to see them.
mercury713
Thinking of going with 1/2 plywood because waters alittle rough here.
I'm going to plywood the sides first so it holds angle.
Yes flat bottom.
